abs module removal
#41
Hi
This is a quote from forum member Sean B posting in another thread:
Anything short of AutoEnginuity will not read these systems. Nor the seat, mirror, BPM, security or other sensors. For General purpose, they (other code readers) are better than nothing, but if you are serious about maintaining a kitty, Get The Right Stuff.
OBDII Code Scanners ** Member Approved **
Here is autoequinuity website address:
Products
I called autoequinuity and found out that the only product they sell that is for Jaguar specific sensors is the PC based scanner with the Enchanced Jaguar expansion (that is compatiable with it).
Here is weblink to their PC based scanner pricing $249.99 plus Enchanced Jaguar expansion (for Jaguar specific sensors) $229.95 a total of over $480:
ScanTool PC-based
Order Online
The other 2 products - their PC pocket model and the Palm based model - are not compatible with the Enchanced Jaguar expansion software.
Jim Lombardi
Products
ScanTool PC-based
Order Online
Jim Lombardi
#42
I can see the raw data stream from the computer on my Scanner application. Is the ABS module interrogated separably from the mail commuter?
#43
Received 2,192 Likes
#44
On my path to remedy the ABS/Stability Control error, I have cleaned all the wheel sensors, replaced my battery with a new one, old one failed a stress test. The error message disappeared briefly after long drive over 30 miles. That would be consistent with a thermal transition causing intermittent connections. So I on to the re solder the power pins in the abs Module.
#45
smtguy (03-18-2017)
trosty
26
12-18-2022 06:40 PM
aholbro1
08-05-2021 05:02 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
abonano
25
09-25-2015 10:43 AM
