ABS Module repair off ebay...anyone used these guys?
97 98 99 00 01 02 03 04 Jaguar XJ8 XKR XK8 ABS Pump Control Module REBUILD KIT | eBay
Just curious if anyone has used these guys before.
its a very easy soider repair inside the module and getting the cover off is harder then fixing the bad soiders on the pump output connectors. most shop can fix it in the shop with out sending it out.you can use a hand hacksaw blade and slowly cut the outter plastic cover on the molded body line and open cover and trace out pump connecters and look close at soider and resoider and reseal and refit to car and you sould be done.
