ABS/TRAC Warning Lights
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
My XJ8L is in the shop right now on an unrelated matter, but I asked the mechanic to check out my ABS/TRAC light issue and he quickly said it would most likely be the ABS pump and told me they typically put in a rebuilt unit for $450.
I mentioned it wasn't throwing a code and he grabbed his reader and confirmed it was in fact throwing a bad pump code that required an ABS reader and wouldn't come up in ODBII.
FYI on the ABS codes if you have the same issue and aren't getting anything on your ODBII reader. I believe I have seen posts here in the forum on sources for the pumps, but am curious to hear from anyone who has replaced one successfully.
First be sure all sensors and plugs are clean and functioning properly before going into the ABS module. I hope this helps http://www.gusglikas.com/images/Auto...e%20Repair.pdf
