ABS/Traction control warning.
Anyone had the above message appear on their dash? Mine appears when the car is in motion but if I turn the car off then re-start the light goes away. It has just started happening - might be a sensor prob?
Steve
Also - anyone replaced their knock sensors???
Steve
There are alot of entries regarding the ABS problem you have. It could be something as simple as dirty sensors,which can be easily pulled, cleaned, and replaced. Mine ultimately required a rebuild of the abs cpu through a company on Ebay. Just search ABS and you will find several threads.
goges
10-05-2015 04:53 PM
zdrapec
09-25-2015 05:49 AM
