ABS Traction Stability Control Failure & Transmission High Temp Warning Msg
Guest
Posts: n/a
Hi,
I have a 98 XJ8L abd the ABS Traction Stability Control Failure is on and I just had my transmission rebuilt. I'm getting another message that reads, Transmission Temp High. I took it back to the repair shop to check the A/T fluid level and it was good....so could this be happening becuz of a bad sensor?
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
