ABS /Traction/stability Failer
Old 04-03-2013 | 11:01 AM
Peter Garrod's Avatar
Default ABS /Traction/stability Failer
On my 1999 Vanden Plas V8 which has 91500miles i recently had the following fixed on the vehcle ;- Brakes -New rotors and pads, Engine -replaced the plastic timing chain tensioners -Engine -replaced the plastic hose ends with the metallic kit. Car has been running great - but now we have the following warnings on the dash 00The ABS symbul together with Stabiility and Traction control Failure. Car still runs okay. What is the solution. Thks Peter G
Old 04-03-2013 | 01:59 PM
Welcome to the forum Peter,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Centre section to the X308 section. Members here with the same vehicle will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old 04-03-2013 | 04:32 PM
RJ237's Avatar
Welcome to the forum. Here is a link to jagrepair.com which will get you started. There are other articles in the DIY sections of this and the XK8 forum. They use the same system:
JagRepair.com - Jaguar Repair Information Resource
goges
10-05-2015 04:53 PM
millertic
09-30-2015 08:11 PM
leep123
09-30-2015 03:41 PM
mrplow58
09-30-2015 08:56 AM
Quick Reply: ABS /Traction/stability Failer
