abs warning and trac/and asc failure light on
Old 10-29-2008, 11:45 PM
Sarc's Avatar
Default RE: abs warning and trac/and asc failure light on
I've had the same thing 3 times now, and it's always correlated to hitting a pothole. I guess I may have a slightly loose connector somewhere that gets upset when the wheel (always the left front) goes down a hole in the road (There are lots here in Cali)
The fix is the same everytime. Stop at the next traffic light (again, there are many in Cali). Switch off, restart and all is well again.
Old 10-30-2008, 10:52 AM
ken@britishparts.com's Avatar
The connector is a possiblity, also a bad wheel bearing can cause this. Wheel bearings fail regularly on the XJ and XK models. We sell the nut removal tool for $150. Also, a bad ABS sensor could be at fault. They are expensive, but don't worry, we don't sell many of those. Start with your wiring idea. It's least expensive.
Old 11-02-2009, 11:31 AM
SuperSport's Avatar
Hey SARC, I'm just starting to get the PotHole Issue. Did you ever find a definitive fix for this? I've been doing the stop and restart "fix", but I don't want to be stranded away from home some day.
Thanks for your input.
Old 11-02-2009, 08:01 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Or get someone with the factory or AutoEnginuity Jag specific software to interrogate the ABS module for codes. Then solve the problem it points to.
Old 06-17-2015, 03:15 AM
Michael Awford's Avatar
Default Usually a false alarm
I've had this warning come up sometimes with my last 3 XJRs, at first it worried me, now I just ignore it, since it goes away when you stop and restart, and ABS worked normally (I did a test on a gravel surface and it chuntered away happily). But I'm no expert, so get it checked just to be sure.
Old 06-17-2015, 04:22 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Originally Posted by Michael Awford
I've had this warning come up sometimes with my last 3 XJRs ..........
Welcome to the forum Michael,
Old 06-17-2015, 04:59 PM
Jhartz's Avatar
But, maybe, you didn't notice,Michael, but you are answering someone's concern from Nov 2009; six years ago. I bet they don't have the car anymore!
  #28
Old 06-18-2015, 01:13 AM
Actually it was 2007 but I only joined the forum to see if there was a remedy for an annoying warning, and I'm sure there are other CURRENT owners with same problem. Your comment was irrelevant and a bit irritating and a bad start to my joining the forum.
99xk8guy
05-28-2024 09:36 PM
D.K
12-10-2023 02:05 AM
99xk8guy
06-05-2023 06:28 AM
Jpav27
07-31-2022 06:43 AM
avern1
09-08-2015 06:25 PM
Quick Reply: abs warning and trac/and asc failure light on
