Ac drain lines on 99 xj8
Samilcar thanks for opening the document. Another drain thaat plugs up and causes flooding is the windscreen/facia drain on the right hand corner of the facia. If it is the passenger side only then it is probably the culprit. The drain can be accessed after removing the facia or also can be found exiting the bottom of the car just forward of the front door seam. You have to rub around until you find a little flexible nub sticking out.
Vern
Vern
car5car
09-14-2016 04:02 PM
shemp
09-14-2016 01:25 PM
