AC only cold at idle
If you like this is the training manual
there is a self test the same as on my X300 on the control panel on page X and a Youtube video
http://www.jagrepair.com/images/Trai...des/703_SG.pdf![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
Don B (07-20-2019)
my memory is a little foggy -- but it must be a common failure point. My friend in parts had me by purchase the sensor when I did the hose.
Was the system working at all before you took it in ? An empty system should be properly checked for leaks (fixed) -- replace RD -- oil check. Properly evacuate and charge.
Well they should have checked further if it was empty -- that's a big leak. I forget the safety system -- I think it read the pressure after the compressor started liek most ...so, an empty system would still engage for a moment. Today they lock out ...
If keeping for a while -- fix once
Once the switch in your pic overpressured it may or may not have resealed as the line pressure came down in leaking
You may at this time be at zero pressure in your freon line or still have pressure in the line
e
negating environmental concerns you may be able to run the AC in your drive and bleed off the freon until the clutch steps disengaging
this would be about the correct servicing pressure
as you drive the car with the AC on you may notice the AC clutch cycling so you would bleed of a bit more freon
this presses would effect your returning back to who serviced it first and any warranty
e
Jhartz (07-19-2019)
Don B (07-20-2019)
The switch appears blown, but maybe not permanently. You need to release some of the pressure (great Youtube by some kid showing how; although may be illegal in your state -- not unlike dumping tire pressure). Then install the new switch (or retry with the old one) and see what happens. If not cold or fans don't come on, add freon (again, some great Youtubes).
Went through two switches until I realized it was over pressurized. Unloaded some freon fixed it.
Z07Brandon (07-20-2019)
The following 2 users liked this post by Z07Brandon:
Jhartz (07-29-2019),
Lady Penelope (07-28-2019)
seawind
05-23-2019 03:38 PM
PinnacleWax
Detailing / Car care
05-08-2015 12:41 PM
stkxjrtech
03-10-2009 03:12 PM
