Accessing a locked trunk in a 1998 XJ8
Hi all:
My friend locked her key and fob in her trunk. Currently utilizing the valet key. What is the best way to get in? Removing the rear seat? I have downloaded the JTIS software, but can't seem to find info on how to remove the rear seat in JTIS (and if I can access the trunk this way). Or is there another way. Someone suggested running a hot wire from the fusebox and I may be able using it to trigger the trunk release mechanism, but was unsure of the particulars.
Do not remove the seat. The gas tank is behind that.
If you remove the license plate and the nylon blind nut on the right upper you can get a long thin screw driver up to the latch. A flex head flashlight like this will help.
LED Flashlight, Greenlee FL2AAF Flexible LED Flashlight | Meritline.com
Don't cut or break anything. It is a 20 minute job the first time. Going forward, get a spare real key. $150 at the dealer.
If it's your only key, then you can't get in the car to pop the trunk. I did something similar once. On my car I went through a hole on the bottom left with a long narrow screwdriver and was able to pop it that way.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 02:56 PM
