Adaptive cruise control
capitaineInsano (04-10-2016)
That's what my x308 has in it, and as far as I can determine, it's completely stock, the symbol doesn't light up, and I didn't notice it until I had taken the cluster out to add a RealGauge.
Was the x308 ever equipped with forward alert (2000)? I just have no idea what that's all about.
As said before, the X308 NEVER had "forward alert" or adaptive cruise control fitted as standard, or even as an option from the factory.
The clocks seem to be from a 2003 or later XK, that did have adaptive cruise control as an option.
Having said that, Jaguar at the time was owned by Ford.... and they are notorious for parts bin engineering, but that dose not explain a later version of the clocks being installed in your car.
Adaptive cruise and forward alert weren't available till 2003, at least in the NAS market. As for other markets, I'm not sure. Since I've been in NZ for the past 5 years, I haven't seen any pre 2003 cars with forward alert or adaptive cruise. When it comes to the wiring harnesses, Jaguar makes them for all the features available, to cut down on cost, and then depending on how the car is ordered, only those modules will be fitted, but the connector will still be there. It also could be that if the Instrument Pack was replaced, it was at a time when they were starting to make updated ones for the facelift models coming out that would have forward alert and adaptive cruise.
NA cars not fitted with NAV do not have the ICE harness to support NAV.
And that is only 1 of many examples......
Vector
collector
04-07-2016 03:43 PM
JagV8
04-04-2016 10:01 AM
