Adding REAR Heated Seats? Pre-wired?
I saw a little write up on how to add heated seat option to the FRONT seats, by putting in the switches in the front center console.
However, my car already has the front heated option. It does NOT have rear heated seats though. I plan to swap out my seats with heated seats and I will get the switches for the rear as well.
-Is the wiring already in the car under the rear seats in order to hook up the new seats?
-Is the wiring already in the car to connect the heater switches too?
OR is the wiring only there if your car came with the rear heated option?
I think the answer is that you may have the wiring present and you may not.
The only way to know for sure is to pull the squab and have a look.
Not an easy job, just follow the instructions and be prepared to pull hard to get the d*mn things out, but try not to break anything, especially the seat belt guides on top of the back seat!
Vector
Vector
