Adjust differential pinion play ?
Hi Guys !
My XJR '99 has a fair amount of pinion play , felt when breaking<>pulling up.
I double checked if it was the diff by turning the driveshaft by hand , clunking noise came from the diff.
Question ; is it possible to adjust the play with the two rings on both side's of the diff (see picture) without opening ?
If so ,what is the right procedure ?
b.t.w. my diff is still on the car , the picture is from some market-site
Thanks !!!
Marcel
Image upload did not work (?)
here's the pic ImageShack® - Online Photo and Video Hosting
(Note the ribbed ring with adjustment slot)
Thanks !!!
Marcel
Received 2,190 Likes
Woznaldo
09-26-2015 11:02 AM
adjust, adjustment, ajustments, axle, backlash, diff, differencial, differentail, differential, gap, jag, pinion, play, preload, settings, slack
