Aftermarket fuel pump that fits without wiring/mounting adapters?
The fuel pump on my 2003 XJ8 went out and I looking for advice on the brand of replacement part. I prefer one as close to the OEM as possible. I do not want to use a wiring adapter or solder in new connectors just plug in the Jaguar wiring connector into the pump. I do not want to force on any spacers/ adapters to mount the replacement pump. I have read the airtex pumps are low in price but have all of the above issues. Any one installed an aftermarket pump that fit/installs exactly like the factory fuel pump?
Welcome to the forum leapers. The Denso fuel pump is available from many sources, including ebay. Lots of information on changing it here, just use the search funtion.
When you have time, please visit the new member area and introduce yourself and your car:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Thanks for the reply and the warm welcome. I've been a lurker for awhile and have read as much of the fuel pump threads that I could find. It seems for the most part aftermarket pumps that have been mentioned on the forum all have some sort of modification required for wiring or mounting. So far I only have three options on my list but would consider anyones suggestions. 1) Original Jaguar part - will fit perfectly no adapters but alittle pricey 2) Airtex E2471 - wiring adapter between pump and Jaguar connector, mounting adapters need tweaking 3) Denso - pigtail wiring needs to be spliced (solder or crimped)
RJ237 (06-03-2014)
Charlene n John
09-28-2015 06:01 AM
deanh
09-06-2015 08:20 PM
