Aftermarket Headlights
I would prefer to fix the headlights myself but can't find the thread for the information. Do you know how to take the assembly a part? Thanks.
You should not need to take them apart.
Take the headlight assembly out.
Thorougly flush the inside of the assembly out with warm water and dish soap for several minutes while holding your hand over any holes. Dump the water. Rinse with warm water. Let dry with lenses facing upwards.
Examine the mating edges between lenses and reflector. Seal any defects with clear RTV. Or, just seal all the way around anyways.
Re-install.
Re-install.
Re-install.
Re-install.
Do you know of a link, or mind explaining details, of how this is to be done?
Thanks SO much.
