Airbag light
The telescopic motor on the steering wheel started misbehaving at the same time. Is this what you mean?
What is the clockspring exactly and how do I get to it?
I mean the controls that are mounted on the steering wheel - horn, cruise,radio.
The clockspring is the device in the wheel that communicates electrically with these, allowing the wheel to turn whilst maintaining contact. It is a ribbon which winds and unwinds as the wheel is turned back and forth, like the spring of a clock. Jaguar call it a cassette module, I think - but the common term is clockspring.
Check the steering wheel functions - if some are inoperative then likely cause is the clockspring. If they are all OK then could still be the spring but there are other possibilities to check out first.
If it is the spring then I can provide step by step guide to replace it, with photos.
Does anybody else have any other ideas?
Initially it seemed like it was the seatbelt pretensioners...those were replaced, but the light came back on after one day. It was ultimitely corrosion in the wiring harness for the airbag. The previous owner had spilled soda on the console. Clear corrosion was seen in the wires, and it almost totalled the car (it was a cat's whisker away from needing a new wiring loom through the cab). The airbag light is now out.
dsetter (07-21-2012)
I would suggest starting a new thread with you car details and the fault(s).
The module has faults logged in it to help with diagnosis but people would rather keep replacing parts than to diagnose and repair.
A generic code reader will NOT access the ABS 'C' codes (CHASSIS CODES) or SRS 'B' codes (BODY CODES) like the 'P' codes in the ECM.
You need to find a shop that has specific diagnostic equipment to read the DTCs stored so you can fix it more economically. Have the shop print out the codes and then start a diagnostic procedure. (or get a quote and tell them to repair)
You can also purchase the diag equipment but it can be 'pricey'.
bob
bob
Don B (01-09-2018)
Well you could keep throwing parts at the problem like the people in this ancient thread.
bob
bob
bob
bob
For what it is worth, I was getting an intermittent air bag light which I tracked to the connector underneath the drivers seat. The connector had come loose from the mounting clip allowing the clip to hang down so adjusting the seat position could displace the connector causing the light to come on.
Don B (01-09-2018)
But if the DTCs were read from the module, you would likely have seen 'Driver's Side Airbag Open Circuit/Short Circuit No Signal' or 'Driver's Seat Belt Pretensioner' or something like that!!
That gives you a clue that the fault is in THAT area so you don't waste time looking at the passenger/driver's front airbag or impact sensors etc.
Time is money and customers don't want to pay you to 'try-this' or 'try-that'!!!!
I like to go directly to the fault, get it fixed and move to the next problem.
Just trying to be expedient.
bob
bob
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
rsa760041
23
09-25-2015 01:33 PM
34by151
09-06-2015 05:14 PM
