Airbag warning light
Old 08-29-2018, 11:13 AM
RoyLittle0's Avatar
Lightbulb Airbag warning light
I have a problem with my airbag light not going off, when I turn the ignition on the light comes on then goes of and then permanently back on again, no flashing, just ON for the check then OFF and back ON again?
Any thoughts on where to start looking ?
Old 08-29-2018, 11:40 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Maybe read the airbag codes
The following 2 users liked this post by JagV8:
Brutal (08-29-2018), motorcarman (08-29-2018)
Old 08-29-2018, 11:46 AM
Received 8,075 Likes on 4,870 Posts
LET THE GUESSING BEGIN!!!!!!!!!!!!!!!!
bob
Old 08-29-2018, 12:49 PM
RoyLittle0's Avatar
If I had a code reader that could read the codes I would have posted them in the description
Old 08-29-2018, 01:14 PM
That is why we are going to guess at the problem.
bob
Old 09-17-2018, 05:09 PM
Curley's Avatar
I had the same problem... I checked everything i could. Then, the other day, I talked with an x jag mechanic who told me to try one more thing. So this is what I did and it worked!. Get in the car, turn the key on but don't start it. then, adjust the steering wheel up and in. then turn off the knob on the side so the wheel doesn't move. turn the key off. Then start the car as normal. He told me it might be the "clock spring" inside the wheel. Can't tell you anymore than that but it worked for me.
Let me know....Thanks
prince_kuja
XJ XJ12 ( X305 )
02-18-2015 12:32 AM
slmskrs
11-12-2013 02:08 AM
JLee
10-06-2012 09:46 AM
jagman1969
11-17-2009 05:56 PM
BLAIR250
07-01-2007 09:54 AM
Quick Reply: Airbag warning light
