AJ26 AJ27 compability
Old 02-19-2021 | 10:38 AM
oldcar's Avatar
Thanks-I tried something like that. Made two hooks fitting the recess behind the reluctor and fixed it to a sliding hammer. No luck...added heat to the cam with a inductionheater. The result is a not to nice reluctor eternally stuck to the scrap camshaft.
Is it a possible idea to grind off the irrelevant tabs on a AJ27 cam?
Karl
Old 02-20-2021 | 02:02 AM
M. Stojanovic's Avatar
Originally Posted by oldcar
Is it a possible idea to grind off the irrelevant tabs on a AJ27 cam? Karl
It would certainly be a possible solution if one of the 4 tabs happens to be at the exact same position as the single tab on the AJ26 reluctor.
Old 02-20-2021 | 08:40 AM
That method is quite different from what I did. Hooks and a slide hammer will not create as much separating (pulling) force onto the reluctor as will a wedge, especially a narrower angled wedge, driven into the spaces between the cam body and the reluctor. I can't remember exactly, but I probably also used a knife blade (very small angle wedge) and hammered it in-between once the cam-reluctor gap opened up a bit.
Old 02-20-2021 | 10:54 AM
motorcarman's Avatar
If you were not a half-a-world away I would just send you a spare AJ26 intake cam via USPS.
Any 'B'bank intake cam from an AJ26 Jaguar engine will work but you will likely have to set the valve lash if you swap cams.
Don B (11-04-2022)
Old 02-21-2021 | 07:43 AM
oldcar's Avatar
Yeah-guess You are right-gross impact is not always the ansver...I will take Your advise and try to wiggle the thing out with a very narrow wedge
Old 02-21-2021 | 07:46 AM
oldcar's Avatar
Thanks-a very nice offer-will try the wedge thing first and if that fails I will buy Your spare.
Karl
Old 09-18-2022 | 05:32 AM
oldcar's Avatar
Thumbs up Update-Finally the engine runs again
Thanks to all for the guidance during the long resurrection of the XJR.
Just swapping of the torque converter flexplate remains before total success.
motorcarman (09-18-2022)
  #28
Old 10-12-2022 | 03:31 PM
oldcar's Avatar
Default Gearbox AJ27/AJ26
Will the gearbox that came with the AJ27 work with the AJ26 ECU after swapping the flexplate or do I have to use the gearbox from the AJ26?
Karl
Old 10-12-2022 | 04:29 PM
I have installed a 1998 XJ8 gearbox (ZF 5HP24) into a 2001 XJ8 so they really don't care what car they are installed. Just keep the original TCM in the car.
The following 2 users liked this post by motorcarman:
Don B (11-04-2022), oldcar (10-14-2022)
  #30
Old 10-13-2022 | 01:41 PM
RandyS's Avatar
Transmissions usually don't care as long as the cuffs and collars match.
  #31
Old 10-14-2022 | 03:36 AM
oldcar's Avatar
Thanks for input-lets hope the AJ26 ECU tolerates the AJ27 AMG gearbox
powellwm
04-01-2019 11:37 AM
vsol
04-09-2017 08:21 PM
blackislegypsy
06-17-2016 09:25 AM
nicatron
02-05-2014 12:57 PM
XJRFanOfBoost
11-04-2013 03:21 PM
Quick Reply: AJ26 AJ27 compability
