AJ26 AJ27 compability
Thanks-I tried something like that. Made two hooks fitting the recess behind the reluctor and fixed it to a sliding hammer. No luck...added heat to the cam with a inductionheater. The result is a not to nice reluctor eternally stuck to the scrap camshaft.
Is it a possible idea to grind off the irrelevant tabs on a AJ27 cam?
Karl
Karl
That method is quite different from what I did. Hooks and a slide hammer will not create as much separating (pulling) force onto the reluctor as will a wedge, especially a narrower angled wedge, driven into the spaces between the cam body and the reluctor. I can't remember exactly, but I probably also used a knife blade (very small angle wedge) and hammered it in-between once the cam-reluctor gap opened up a bit.
Don B (11-04-2022)
motorcarman (09-18-2022)
#28
