Are all 98 xjr cranks the same
http://www.jagrepair.com/images/Auto...Code%20168.pdf
Gets into bearing measurements around page 53 of the pdf.
I don't want to answer concretely cause I don't know for sure, not experienced enough to be rebuilding engines yet, but that guide should get you pretty far.
nilanium (12-27-2016)
If I got a used crank do I mic all the main and rod journals and get the bearings to match regardless what yhe block codes say?
Also I was looking at the size graph and some had 2 different color coded bearings.that dont make make sense to me to put 2 different size bearings on the same rod or main unless im not understanding it.
From what I remember in my reasearch the only way for the dealer to sell you new crank bearings is for you to bring the old one to match and making sure you know the location and orientation. From what I remember there is some measurment on the block for the journals and somehow the crank has to be matched to it, read the manual I know it's there.
I also know there is someone else selling oversize bearings too. I just don't remember which tuner it is but if you search here you will find it or someone else will chime in.
