Are all X308 differentials the same?
I have never seen a 3.2 liter engine. I worked on Jaguars in Texas USA but I don't think any were imported to North America.
I did install a 3.27:1 diff into an XKR from a UK 3.2 liter X308 that a customer bought and had shipped to me.(just the diff)
I had to cut the pinion shaft JURID extension and swap the prop shaft drive flange.
The customer also had the TCM reprogrammed to the new ratio.
Vonnslingo (09-12-2022)
@chirpy made a little bypass module so no need anyway
Addicted2boost (09-13-2022)
The car had a larger lower pulley for the SuperCharger, larger intercooler radiator and pump as well as the changed diff ratio and it accelerated 'briskly'.(wow)
I think a standard XJR is brisk enough for most, and insanely reliable if taken car of, way more so than the NA cars, ZF!
For those that need a 3:27, there's plenty this side of the pond if you want to try, NA is a matching TCM, S/C is a reflash - NAG1/722.6 etc...
motorcarman (09-14-2022)
