Already posted on new members forum, but
The mechanic informed me I had a blown head gasket. This is usually caused by over heating or engine explosion.
It didn't over heat. My son reported engine explosions that were loud and scared him.
Could the explosions be caused by faulty replacement of the timing chains and tensioners?
Going back and rereading all the posts, it appears the timing chain jumped, caused a small explosion and blew the head gasket.
Or, the chain became off, caused the explosion blowing the head gasket then jumped and froze the engine.
Obviously I'm not a mechanic but it appears pretty clear that since the engine never over-heated, the timing chain and tensioners were replaced as a prevention, then with less than 1,000 miles all this happens, it leads back to a mistake in putting in the tensioners and timing chain.
At least, that appears to most logical based upon my limited knowledge.
I think we should leave it to the Jag techs on board here to tell whether the two can be related or not... I suggest, in order for this to get maximum attention, that you generate a new thread with the title of "Can a faulty tensioner install cause a blown headgasket?" or equivalent, with a detailed description of the process so far.
There is always the possibility of coincidence, but if one or more of the techs here is able to state that this is a viable cause/effect from the bad tensioner install you will have ammunition on your side.
