Alternative Valve Cover Gasket
I'd like to find a more robust and less leak prone valve cover gasket for my Jag.
Is there something like a FelPro gasket available? Felpro's site says no.
I replaced one and its leaking. I may have over torqued it or a section may have slipped out to in. Regardless I'm leaking oil from the gasket and I'd like to fix it once and for all.
Eric
Eric
If you do not replace the (14?) isolators, the gasket and spark plug well seals will not have as much 'crush' applied and will probably leak soon after gasket renewal.
The 'isolators' are made of a rubber type material and will deform over time. They provide the pressure to the cam cover needed to seal.
You could just use metal washers/spacers IF you are REALLY careful to not overtorque and crack the plastic cam cover.
I just use new ones and go on with my life.
bob gauff
bob gauff
Eric - are you looking for a FelPro set compatible for your jag, or saying you installed a FelPro and not satisfied? I actually replaced all mine with a FelPro set and been leak free since. I did respect torque wrench settings though. Got the set at Advanced Auto Parts for roughly $60. If interested, I can send you part number. Was listed for Lincoln LS.
The gasket the Jag dealer installed a year ago was leaking at the lower rear corner. Took the cover off, cleaned the head mating surface very carefully and smoothed it down with 400 grit, put it back together with a dash of Permatex black silicone sealant at the two points where the castings are joined. No more leak.
Moral of the story : the gasket is only as good as the surface it is applied to.
aholbro1
08-05-2021 05:02 AM
1964Daimler
09-09-2015 11:20 AM
