alternator problems i think
ok so my cars lights is dim i had my alternator and battery checked both two seperate times they are both checking out to be good .....my car will run for about 1 to 2 hours before the lights go dim again i dont have a clue as to what to do any help anybody ?........the car starts fine until the battery goes dead then all i hear is the relay click when i turn the key over
Guest
Posts: n/a
First, u need charge battery at least 30 minute or full charge, load test.
Second, you need let the car run for 1 or 2 hours with DVOM meter hook up direct to alternator, positive clip at ALTERNATOR B+, negative clip on ALTERNATOR CASE and watch, sometime alternaotr will fail when it get hot or run with a long time
Hope this help. Let me know if this is fixed
aholbro1
08-05-2021 05:02 AM
Dicque
09-19-2015 12:53 PM
