Another LS Swap Project: 2000 XJR
#61
I'm using the OEM Camaro SS catalytic convertors (all 4) and it does a pretty good job quieting things down. You certainly know the exhaust is there on the highway, but not what I'd think is significant drone. That said, all of the 2k miles so far has been with the windows down (black on black in Texas sun/heat with no AC until this week doesn't work with windows up), and the 45 minute ride on the highway was the longest so far with windows up. I'll try to get a mov/mpe/mpeg file of it on the highway for the sound. I know it's not likely to ever be as smooth sounding as the Borla "Touring" setup on my truck.
What are you using for exhaust on your LS2/T56 Jag other than the Magnaflow?
#62
Hope you can sort out that flange vibration. If you're using a bolt on flange adapter I wonder if a shop could balance it assembled to ensure it's made correctly. I went one piece driveshaft also, and used a one-piece Sonnax adapter made for BWM I modified by enlarging the pinion pilot hole. A little spendy but trouble free mercifully.
Steve W
02-02-2018 05:10 AM
jduffy
01-08-2011 02:43 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
