Another sunroof question
As I said in another post that I was replacing my headliner but at the same time redoing my broken sunroof. I took many pictures but am now having a problem. I removed the sunroof frame and motor, replaced cables and tilt open mechanism and after replacing every thing this is what I get.When I push to tilt it works OK, then when I push to open it returns to open about 6 inch from fully open,when I push to close it goes to the tilt again. So what it actually does is ether open or in the tilt position with no close. I tried the info from the other post on how to reset but with no luck.When I push and hold in tilt I can hear the relay clicking but no movement. I had thought that sense I removed the motor there must be some kind of adjustment on the motor gear release located below the motor this allows you to use a flat screwdriver to move the roof were you want it and disengage the motor.Does anyone have any answers??
Bill
98/XJ8 VDP
Bill
98/XJ8 VDP
Guest
Posts: n/a
All- just bought a used '98 XJ8 with similar sunroof issues. I've replaced the modulator (previous one just kept running) and am in the process of adjusting the "timing" on the new one. A previous poster mentioned 2 white indicator marks to be adjusted when in the closed position. Would it be possible to get a picture?
The mod. that I purchased is an iNalfa (sp?) and I'm not sure if this is an aftermarket part, or original Jaguar part, so the white lines may not be present. I may have to just sneak up on it, by turning the timing gear in the modulator a little bit at a time as suggested.
Thanks Guys
Thanks Guys
kabs3012
09-12-2015 10:40 AM
jagent
09-12-2015 09:10 AM
