Antenna mast hole
I unplugged the the antenna cable connection from the power unit and connected it to a 2 foot piece of coaxil with the center wire stripped long enough to make contact, then have to tape because of course there are no threads to screw the co axil connector to.
The reception is remarkable except for the stations that were low signal even with the antenna extended anyway.
I'm in a Chicago suburb, but not sure how this would work for someone in the sticks.
Stripped long enough to make contact with what? What did you have to tape the coaxial cable to? The antenna cable? Sorry for the dumb questions. Is this similar to the wire antennas that come with home stereos?
With the center wire going to the radio, yes to the antenna cable that I took off the power unit. No its the black cable that cable companies use, although I guess another wire would work.
I might experiment with a longer wire, but its not really necessary.
Reception is perfect now.
My antenna has broken twice (not broken currently), and I like the idea of the cleaner look, so I may play with this idea. I am in a fringe area, so it may not work, but I'll check it out.
Did you leave the braided wire on the cable? So only the center connection is connected on one end? I would have thought the shielding would prevent reception...
