Antenna stops retracting
Maybe something is snagging that causes the motor to stop while it's on its way down. If you take the mast out is it easy to slide in and out by hand? A slightly kinked section could cause it to bind up occasionally and stick on the way down I suppose. Taking the mast out will also completely unwind that toothed string the motor uses to extend/retract the mast, so you can reinstall it in case it's gotten unsettled somehow.
If the mast itself is binding up, they are cheap, I think in the $15 or less range. Motors can be a bit more..
Replacement aerials are also available if you require one, but I think you could probably also pinch one out of a universal unit too.
I took mine apart to apply fresh grease to the guide, as Bob says be careful. Mine operates silently now with the fresh grease. It also helps to keep the aerial polished to aid movement.
JZjaguar (01-11-2017)
