Any coolant cap removal tricks ?!
Sir King,
Tried large channel locks? When my X308 was new to me I had to remove coolant cap that way several times. If cap is old I recommend replacement. Mine began to lock itself in place about the same time it no longer reliably sent coolant to the underfender tank. But did occasionally send coolant all over tank.
Perhaps "Renew older coolant and gas caps" should be added to "tensioners" as standard X308 maintenance step.
King Charles (12-15-2016)
And if the cap hasn't been replaced in the last three years, the owner should
be dragged out into the street and shot ;o))
The arrangement is similar to any jar.
The goal is often to enlarge the cap while the container
neck remains the same size.
Have channel locks at the ready, pour a kettle full of boiling
water over the cap. Try removing immediately.
Knowing that these like to stick, I smear the thread on the
neck and the interior of the neck with silicon grease.
I had to use a hair dryer on my old MB wagon a few months ago -- Brake fluid tank cap. The cap on the Jag does get tight -- don't over tighten. I have had to use a rag and a large channel lock previously -- not sure I would do it now without giving a little heat.
I heated the MB's cap due to the cars age (2002) ... I did not want to snap any of the tank mounts. I would have the same concern with the Jaguar's tank -- older plastic coupled to a known weak point. Using a suitable plastic friendly grease on the threads is my typical remedy -- I always have a tube of Jack's multi lube around as I have a swimming pool.
regular inspections!
As Eric has eluded to, the cap is designed in such a way as to work without excessive tightening ;o]
This problem is also exacerbated by the coolant as it ages.
As it gets older the additives are depleted which in turn reduces it's
'lubricity'.
be used is the problem!
With the natural tendancy of a lot of grease monkeys and owners to
screw the bejeezas out of it when it is unnecessary!
This is the 21st century fer chrissake!!!!!!!!!
And your understanding would be?
It's a cap -- one puts it "on" and then can't get it "off" ... that's my understanding.
Some may be thinking .. well the cars are old and something is occurring that is now making the caps difficult to remove. I'm explaining that the caps have always been temperamental .... and can stick when properly installed. The caps/tank are the problem.
Bollocks!
I'm sure you are aware that the pressure cap is replaced as a service item,
usually when the coolant is changed every three years.....but then again....the average seems to be never....along with the coolant and then the moaning and bitching starts and it has to be the fault of the vehicle or the manufacturer....give me strength!
