Any differences between an OEm x308 superhargerfrom 1998 vs 2002?
Any differences between an OEM x308 supercharger from 1998 vs 2002?
Hey guys. I am looking for an x308 Eaton M112 supercharger to modify/rebuild. This will greatly reduce my down time, since I will just have to swap in the "new" unit for the "old" unit. It will also allow me to return my car to stock if I ever choose to do so, and using the original parts. But the only one that I can find in my price range is from 1998. Are there any differences between a unit from 1998 and a unit from 2002? Also, I would need to find a set of intercoolers to modify to go along with the supercharger. Are there any differences in those between model years? Thanks in advance
Last edited by Johnny_B; 03-28-2018 at 11:49 AM. Reason: I suck at typing sometimes :P
Received 1,794 Likes
There are many available, have you checked on this site... Car-Part.com--Used Auto Parts Market ...you can do it by year and even localize it. Not knowing your budget, I saw them from $200-800 doing a nationwide search.
Johnny_B (03-28-2018)
According to the parts catalog there are 2 options for the 4.0 liter supercharger VIN's up to 878717all use the same supercharger. Then from VIIN's 878718 onward use a different supercharger. Parts catalogs don't give info for the difference.
You just need to make sure the one you are getting is in the same VIN range as your existing.
If you look at this page it provides the part numbers. If you select for each VIN option you'll see that the superseding part numbers end up the same for any model year.
I hope the link works.
https://www.jaguarclassicparts.com/u...unting-bracket
Highhorse (03-28-2018)
Dear gents,
I can't tell about the reasons why there are four different revisions of the supercharger. Since the mounting brackets and points remained exactly the same over the model years I just can think of minor details which were altered.
But when you're at it then I'd suggest to get a Gen V Eaton M112 from the 4.2 SC engines (S-Type, x350 XJR, 4.2 XKR) as their bearings had been improved over the Gen IV blowers of our cars. This improved the bearings longevity drastically.
It's a out-of-the-box fit - no need to adjust and/or alter anything. Just plug and play - same bolts, same mounting points, same pulley, same dimensions etc. The only thing you need to buy is the gasket between supercharger and the intake air elbow from the 4.2L engines (part no. AJ83292).
I can point you to the thread where I had done some pictures of that upgrade, if you're considering this upgrade.
The following 3 users liked this post by xjr2014_de:
Dear gents,
Yes, they do share the same dimensions etc. That's the reason why in my mind this upgrade is a No-Brainer. See https://www.jaguarforums.com/forum/x...engine-176755/ for more details (post #9).
Even if I worried a bit about the slightly thicker new gasket there had been no issues when fitting the intake elbow to its brackets. And the "offset" of 1 or 2 mm doesn't have any impact on the EGR-valve's or throttle body's position either.
Do a quick search around the forum and you'll find some more people which have done it. I didn't refurb the entire blower - I just replaced the coupler and the oil - that's it.
I have driven 20k miles with this setup so far - works like a charm!
In terms of originality I'm quite relentless, but I'm always looking for some useful and sustainable (and reversible) upgrades which help to prolong the engine's life a bit. E.g. the intercooler pump upgrade with the higher flow Bosch 010 version - helps to keep the hot engine cool :-)
Cheers, Alexander
Cheers, Alexander
beady
01-14-2016 06:43 AM
BruceG
08-12-2013 02:41 PM
Baloo
09-09-2012 01:29 PM
mrmister
05-29-2012 08:19 AM
gabrielduenas
10-03-2011 01:18 PM
