Any possible chance to get the trunk open?
Old 11-07-2018 | 10:47 AM
CharlzO's Avatar
Curious on those pictures, since I don't remember what it was like when I pulled my subwoofer out. Is that a factory opening, or was that cut in by a previous owner to access fuel lines and pumps?
Which brings me to #2.. in my XJR, there's quite the gas tank behind the rear seat, so opening or no, there's not a whole lot that would be done to access the trunk.
  #42
Old 11-07-2018 | 11:25 AM
Carnival Kid's Avatar
Originally Posted by CharlzO
Curious on those pictures..............., there's quite the gas tank behind the rear seat, so opening or no, there's not a whole lot that would be done to access the trunk.
That's what I was thinking too.
  #43
Old 11-07-2018 | 03:55 PM
grandell's Avatar
Pretty sure that's an X350, not an X308
ericjansen (11-07-2018)
  #44
Old 11-08-2018 | 10:19 AM
rf69's Avatar
I don’t really know to be honest I did that because I needed the trunk opened and I was desperate.
i bought the car used 5 years ago and it is a Jaguar 2004 XJ8 a 350 for sure.
I was told that there’s not access through the rear seat
but I found that aluminum cover plate and the opening is from factory not doubt about that . I was really surprised and happy when I saw that opening
  #45
Old 11-08-2018 | 10:39 AM
CharlzO's Avatar
That's the difference - two different cars. The X308 has the gas tank smack dab behind the rear seat, so even if you did cut a whole in the rear seat back (there's no factory opening), you'd have no way to access anything, since you'd just have the tank up against it.
For the X308s, the only ways I know to access the trunk, are the button on the fob, the key itself, trunk button on the lid, and the dash button. With a dead battery, then you're stuck with the key, or if the cylinder is froze or broken, you can try to connect cables to the positive post under the hood to provide power to then use the power releases. And last resort, drilling the whole behind the license plate which can then allow use of a thin screwdriver or other tool to manually release the latch.
It is one of the few things I wish the car had, was a pass-through rear seat, but moving the tank would mean the lines of the X308 wouldn't be as slim as they are.
BadKat174
05-26-2023 01:29 AM
DuhCar
09-11-2015 11:58 AM
findre
09-10-2015 06:46 PM
speacock
09-10-2015 01:14 AM
kstevusa
09-07-2015 02:12 PM
Quick Reply: Any possible chance to get the trunk open?
