Any suggestions on how to R&R the upper wood on the steering wheel?
Recently, the clear coating on the steering-wheel wood is starting to crack on the top bar of the wheel. It isn't a huge problem, but when I slide my hands past it I'm catching little sharp-ish edges instead of the smooth coated wood, and it has become a bit annoying.
Does anyone have a suggestion on how best to R&R this thing? I like the wood and hate to cover it up with a steering wheel cover. Could it be sanded down a bit and hit with some new clear finish? Anyone have suggestions on products to use, or has anyone done something like this to their wheel?
Received 1,797 Likes
Contact this guy he does awesome work & I'm sure he could create a custom listing to handle your wheel.
https://www.ebay.com/itm/Jaguar-Xj8-...r/123395743601
The wheels are rather easy -- proper liquid prep and light sanding. Spray varnish w/ UV protection. Recently did my triumph -- wheels don't show the imperfections like the flat panels do. You can always send it out ..... or even buy a used one. One of the guys in our group had a nice black one for $100 bucks last year.
It's important to not overly sand -- you just want to prep and redcoat the clear. Typically the top of the wheel gets hit with the sun and fingernails -- little rough. A couple coats in that area and then coat the rest -- you can't see that top area when it's on the car anyway. Using a good liquid prep is important to remove any wax and built up junk from years of hand location etc.
sg18438
02-22-2017 09:35 PM
XJsc-guy
01-16-2016 03:14 PM
weisberg
11-04-2014 08:46 PM
JKK
07-26-2010 07:55 PM
Xistnnn
06-28-2010 08:36 PM
