Any thoughts on this?
The wood issue yeldogt referred to is a factory problem that surfaced in the '00 MY. Looks like a little milk was added to the clear finish. Jaguar replaced a lot of dashes free but no longer does that. Only fix is a complete refinish for about $1500.
The most critical 'upgrade' is the replacement of the plastic cam chain tensioners. If you cannot determine that this has been done you absolutely must replace the original plastic ones ASAP. That means immediately. Penalty for a failed tensioner is a replacement engine. If the owner cannot verify that this has been done you have a $1200 negotiating point ($800 at an independent, $200 DIY).
See the FAQ sticky above for a complete check list of inspection items.
Jaguar did have some issues regarding the wood on cars that had sun exposure - and they did fix a lot of them. But -- it required the sun .... so look to make sure the car does not have any paint or interior issues from sun exposure.
The 2000 will need to have had its water pump replaced - tensioners etc.
The original owners of these cars had the funds to buy and maintain them -- and so are often great cars to purchase. They also normally have garages.
Most of the guy's I know keep records -- the white ones are often exceptions to this.
Why are people such liars? Not the original owner, no records, car was a bit of a pig.... Car wasn't even registered.
Looked at an '02 with 83k. ABS and coolant level lights on, 'computer' whirring in the background. No records of chain tensioner guides.
Did see a '99 with 70k in a closed used car lot. Matching VINs, wood perfect, will go back tomorrow and check it out.
abonano
25
09-25-2015 10:43 AM
Dickie_L_J_O
09-13-2015 07:44 AM
