Any tricks for removing the door panel in a 03 XJR
The used door lock actuator arrived Friday. Now I need to take the door panel off to put it in. Only screw cover I see is for the inside door opening lever plastic trim piece. Is the rest simply held onto the door with plastic clips or am I missing some screws or bolts looking at it. Its a rear door btw.
I do not know about the rear doors but the front passenger has a really strong stuborn metal clip about midway up towards the right side. The best way to remove this one is to look into the door panel from the bottom once it is loose and you will see two phillips screws which can be removed. You may also be able to lift this one up and out of the car once all other clips and screws are loose. Have fun! You get a lot more respect for the car when you see how well the panel is attached, atleast compared to american cars.
Removed it today, 1 in the door lever, 1 in the handle and 2 on the underside. Replaced the actuator and it works great. Too about 2 hours all in all. New motor is a 3 wire, old was a 2 wire but the factory wiring harness had 3 dins so not sure what the 3rd wire is for but oh well, it just weighs a bit more now.
99xk8guy
06-05-2023 06:28 AM
