Anyone Disabled the EGR?
I can't say for certain, but my egr valve was plugged up a couple of years ago and it was throwing EGR malfunction codes. I took it apart and cleaned it up. That took care of it.
What about some JB Weld.. or the 2 part epoxy sticks? Maybe you could repair it with that, or check in with some of the guys who are parting out in the private sales section. You don't have much to lose in trying to repair it. I fixed an exhaust pipe flange on my son's 2002 Ford Escape with the putty type metal epoxy and it has held up for a few years.
Honestly, when I put the motor together I cleaned the elbow/egr and throttle body clean of any deposits. I was hoping to cap to keep the crap out of the motor
Fair enough... actually I edited my first reply, as I had meant to suggest the putty sticks (I am not sure of the correct name of the stuff). If blanking it off does not work, you cold give that stuff a try. It would probably be easier to use than JB Weld and in my case it has remained intact for 3 years on an exhaust flange.
Let us know how it goes in the end, because if mine ever acts up again, I would be happy to blank it off. It could be that I got codes because the valve could not open and close properly. If it is not sensing gas flow or pressure, hopefully it would work blanked off
