Anyone run Nitrous on their XJR?
Here you can see dyno charts of stock XKR 4.0 with and without 100hp nitrous shot.
http://www.powerhouseautomotive.co.u...Dyno-Chart.jpg
1/4mile ET dropped down 0.8s ( 13.6 - 12.8 ), but the driver told me that he was able to use the shot just after 60mph because of traction problems ( poor street tires and no LSD ). The NOS system is direct port incetion one. You can see some pictures of system there also.
Sam
Sam
My favorite quote on Nitrous is, "Nitrous is like a really hot chick with an STD. You really want to hit it but you know there will be consequences."
That said, I've successfully run Nitrous in both street driven vehicles and boats. In every case the added torque always manages to find the weakest link in the drivetrain. That's the consequence.
Using it as a cooling agent will work to get your intake air temps down and should add a few ponies but have you considered switching to E85 instead? Since you live in the land of corn fuel it should be plentiful and it's benefits in a high performance engine are many.
To better explain, I recently finished a buildup of a 1967 Camaro where I installed a 6.0 Liter LS engine with an Eaton 2300 CC blower and no intercooler. On pump gas premium, the biggest issue was the high intake air temps forced us to use a lazy ignition advance curve to avoid detonation. Switching to E85 had a "cooling" effect and the 12 extra octane points allowed us to tweak the advance curve enough for an 86 RWHP gain over pump gas.
The change over to E85 would be a lot easier and cheaper than a nitrous setup. The trick is to figure out how to deliver 27%-30% more fuel to the engine. The most simple way is to bump up your fuel pressure at the injectors. I'm not sure if the stock fuel pump is up to the task of the higher pressure so that may need to get changed and you'll want to bypass the fuel pressure regulator with an adjustable unit.
Ken
Ken
Ken
Ken
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
