Anyone upgrade the J gate to a tiptronic shifter assembly?
Since it's an MB trans and the TCM is MB I'm sure it would be feasible (don't confuse with easy) to swap in a Tiptronic shifter assembly.
I've been looking around and reading some MB boards and apparently some MB guys do it as MB cars didn't come with that mechanism till about 2001.
So, apparently the EGS51 has to be swapped with an EGS52 at the same time to work with the new shifter assembly.
Now the big problem in that scenario is that the parts are $$$, which I'm not willing to dump into a 15 year old car.
However, I've been doing more digging and cars such as 5.7/6.1 Dodge Magnum, Charger/ Chrysler 300 come with the same 722.6 trans, EGS52 TCM and a tip shifter assembly. They are cheap as dirt since they are dime a dozen so I'm sort of itching to see if I can make things work.
Anyone tried something like this?
GO 4 IT!
There are cars that have the tiptronic conversion here in the UK, mainly XKR's - Norman's had this before going the manual box route. Avos might know more...
I've read they're slowish - but it'd be worth testing the system out on one of the cars you mention first and seeing if it's a desirable conversion before setting about it?
n2audio
17
10-09-2015 10:53 PM
UKnFor-dluv-expat
09-26-2015 08:40 PM
