Aslightly different situation with my tensioners
I currently own a 2000 XJ8, upon startup there always been a light ticking noise, one day i turned it on and their was a loud thumping, i took it to my mechanic and it was the secondary tensioners, i got them replaced but
i still get a light ticking everytime i turn it on in the morning, i changed to different oil brand (royal purple) and i still get it, performance of the car is great.
Guest
Posts: n/a
RE: Aslightly different situation with my tensioners
Maybe tappet noise? If it goes away, when the temperature gets warm enough, that may be it. I don't know how it should sound when the pri. tensioner goes, but when the sec. goes, the noise should last only for a few seconds at most (until oil pressure builds up). Tappet noise lasts until the engine gets warm (so valve parts warm up to decrease mechanical gaps). This engine does not have hydraulic lash adjuster, so it does tend to make tappet noise, I think.
Anyway, you should talk to someone who know the sounds...
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
