Automatic 4.0 V8 Nearly stalls upon startup
I cranked up the car today, and a few (7ish) seconds after it started, the RPMs dipped down to 0, then went abruptly back up to 900. Then it happened again. What on earth is this, its a bit worrying.
It didn't die, but it wasnt running correctly. It drove allright about 1 mile and havent started it since. No warning lights or anything. The engine was 1 line above "C" on the temp gauge.
Well, about 50 miles a week of highway driving is what I do, plus the odd 50 on surface streets... Monday I went 30 miles round trip on the highway, and then last friday 40 miles highway to the dealer, so it's been nice and warmed up plenty. I wouldn't let a Jag just sit there dis-used. I know what goes wrong when you leave a car and never drive it. I haven't driven it since the near-stall, I don't know what to think. Maybe it won't happen again.
Side-note, the car just passed 50,000 miles and seems to have opened up a treasure-trove of small issues. Maybe a lot of routine maintenance is in order (and it's had oil changed, 4k ago Mobil1 Synth.)
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Have you read the codes/pending codes if there are any? Are you worried its a timing chain issue? Have they been changed? Is a 2002 at risk for the timing chain issue?
PO172, Po175. I drove the car today, and got the same old codes... she's going back to the Jaguar dealership monday. They replaced an MAF for the same problem 7 days ago. The timing chain is not an issue I don't think is prevalent on a 2002. Tensioners, maybe, but I'm not looking at replacing those anytime.
Are you paying full price at the dealer or do you have a warranty/hook up? I want to know how much they are charging. Its $140/hr near me.
My car was running lean with misfires and restricted performance. The issue went away when a missing coil cover screw was replaced. It makes no sense that this cured it.
Maybe an oxygen sensor, MAF or leaking injector is the problem?
I would clean the throttle body/butterfly valve with spray cleaner and the part load breather tube orifice before I took it anywhere. Clean the area where the valve meets the throttle body. Gunk elsewhere is only an appearance item.
$3 vs $300+.
The part load breather tube can be found on a search.
$3 vs $300+.
Sure it does. The coil was not staying completely seated on the plug. The spring contact is quite tiny.
Maybe ... indirectly.
The unburned fuel is seen by your O2 sensors, the ECM will then (probably) try to trim back the whole bank if not the whole engine. If it does that, then yes, it will go lean because of the attempted compensation.
Someone else may chime in and say this is all wrong.
kaotikd
76
05-24-2016 02:23 PM
pSyCoSiS
07-15-2012 08:04 AM
