Average cost to have independent shop preventatively replace tensioners??
Approximately how much does it cost to have the tensioners upgraded/replaced and independent shops? I've seen the $600 figure, is that for a shop to do it, or just for the parts to do it? I'm assuming that is labor and parts, but I don't want to assume.
I live in the San Francisco Bay Area if that helps.
Thank you in advance.
I am new here and don't have enough posts/days to do a search, so sorry for asking what I'm sure is a very often asked question.
Welcome to the forum! You should be able to do a search, just limited on downloads. Say hello to a few folks in the new member section and you will be there.
Ford parts for the upgrade, tensioners and bolts, are about $130, FelPro gasket set about $40. Labor about 4 hours. Labor rates vary widely. Some will only provide parts.
Not a difficult job, if you would try to replace spark plugs you can do this.
It would help if you would put your model/year in your signature
JimC64 (01-04-2012)
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
rootbeerlover
08-31-2015 03:37 PM
Bcrary3
08-31-2015 11:29 AM
