AVOS, this is the first time I am hating when you are right ;)
I don't know this dyno, and why it is showing lower numbers, have you asked what the reason is?
What you could do as double check, do a new run and see if that at least gives about the same numbers that will raise confidence in the sense that you can get consistent numbers.
You’re a/f ratio is very off; if that would be from the tune it was a dangerous tune to start with. You might want to double check if you do have a tune, the leaner mixture could also be caused by something else.
Not sure why you read so low in boost, don't think its low from the coatings but would be #1 to find out, #2 lean mixture, solve it/or know why its off, you may even find new power there, once done do a new baseline.
This is all my opinion, there is no need to follow it!
I agree it starts off way too lean in the lower rpms. I will keep a close eye on the a/f ratio on each run. I have bought a a/f gauge to put in the car to reduce the chances of melting something before it gets to the dyno.
Since I now have ported intake parts a new baseline cannot be done. But we do know that my baseline was very close to Robs and Marcs, so that is just how this dyno reads. The brand is dynaflow, this is just how they read. Dynaflows read low, Dynojets read high.
Also as to the boost. I've found a fresh genV blower with very low miles that will be fitted with an upper pulley. When I get the TB back from Maxbore I plan on adding the new blower then doing a new dyno run with the added mods of:
82.5 mm TB
port matched elbow
ported and polished intake manifolds
Fresh blower with upper pulley.
If the air fuel gauge says I am not about to melt something, I will take it to the dyno to see what gains these mods give me. If Mr. Air Fuel gauge says too lean, I will install the fuel pressure regulator and see if that helps get back into a safer zone first.
WaterDragon (10-01-2012)
Viapa and Thundercat made 373 and 380 rwhp respectively with same mods on a dynojet.
Looks like they still had the stock restrictive intake tube. A proper intake would be good for 30 hp or more. If they had stock cats, add another 10 hp for downpipes. Porting inlet, manifolds, larger ported TB; another xx? hp.
Not saying you can just add these gains directly to their numbers above, but gives you an idea.
#28
Chassis Dyno Guide Photo 18
Dynos that can apply load need to be calibrated/baselined (don't know the right word) as far as I know, so you could check when theirs was.
Also ask if they used the inertia method (like an Dynoyet) or with a load (eddy current).
Wolfy
05-28-2024 08:06 AM
