Backseat Removal
Hello. I need to remove the rear seat on my 98 VDP. I have removed the seat cushion and now I am trying to remove the seat back. I removed 4 screws along the bottom of the seat back and I was thinking that I just needed to lift the seat back and pull out but it is being stubborn. Before I break something important, I was wondering if anyone out there knows if there is something else I need to do.
Thanks in advance.
Joe
98 VDP
Thanks in advance.
Joe
98 VDP
I hacked into my CD changer to hook up my IPOD a few weeks ago and had been wanting to get the wire hidden since then. Just now found the time. I used a post by SARC - titled "Best way to route a wire from boot/trunk to centre console cubby box." He describes coming in through the right side of the trunk.
As described, I removed the felt lining in the trunk and then threaded a coat hanger between the trim pieces on the right side B pillar where it meets the rear deck under the back window on the inside. Then I used some electrical tape to secure the end of my wire to the coat hanger and pulled it back through to into the cabin. I used a screw driver to gently pry the trim pieces apart a half inch or so to make this process easier.
Snaking the coat hanger through took some fiddling around - it came through small vent on the inside of the trunk. Small plastic piece right under the pillar.
Joe
98 VDP
Joe
98 VDP
aholbro1
08-05-2021 05:02 AM
doctordeuce
09-12-2015 08:30 AM
