bad fuel sending unit ?
hi guys I think I have bad fuel sending unit the fuel gauge needle was working fine before I change the fuel pump but after I changed the fuel pump the needle was not accurate and goes up and down if I turned hard to right or lift side ! so the mechanic opened the tank and took a look on the sending unit and did some work on it it worked fine then now it just go from 3/4 to full only for example the gauge can only go full or 3/4 doesn't go to empty or half at all what to do ? ist bad feul sending unit that need to changed or its something else?
2002 xj8
2002 xj8
the fuel sending unit is inside the tank in the right side time to change it?
If you remove the boot liner, exposing the tank, I think you will see the sending unit below the midpoint on the back wall of the tank. I have attempted to attach a diagram.
1998-2003 Jaguar Fuel Tank Assembly NND5908AT Ft. Myers Jaguar
jeffrimerman
09-14-2010 09:23 AM
ralph305
07-26-2009 02:18 PM
