Bad knock sensors 2000 XJ8
I replaced Bank A sensor once, not too difficult. As said above, make sure to tighten to recommended torque (can't recall, but I am sure can be easily found). These are indeed fragile components and too tight can damage them (and too little would cause to 'wobble' and also not function properly). Cheers
Try this thread:
https://www.jaguarforums.com/forum/x...ine-faq-45963/
I used AutoZone to buy 2 knock sensors for about $65 including shipping.
See the last page in the above thread. They are made by WELLS.
P O R - Press On Regardless
Ok. I have the sensors, after research on the forum, it was determined I can use SU7012 in place of SU7015 (a difference of $100 each). Getting ready to install them. Can anyone show me how to remove the connectors from thermostat housing clip so I don't break them.
Is the engine fault light on after the knock sensor replacement? If so,
use your OBD-II reader to clear the codes. Then start the engine and run
it for about 5 minutes. Turn the engine off and recheck your engine codes.
Generally the first displayed engine code is the first area to check or repair.
Another area to explore is your driving habits.
Do you drive more than 15 minutes per trip or less?
Do you use Premium grade fuel?
Do you use a battery maintainer to keep your battery charged up?
If you drive your Jag less than 400 miles a month with trips of 15 minutes or less,
then your battery is not being charged enough to be reliable.
Also, is your battery more than 5 years old? If it is then get a replacement soon
and have an external battery charger lead installed for a battery maintainer.
This will extend the life of your battery if you use a lot of plug-in electronics via
your cigarette lighter ports.
There are several postings about a DIY battery charger leads istall in this forum.
Throttle body, bad coil(s), fuel pump, plugs, the list is somewhat endless.
Clear the codes and report what comes back.
Also, make sure the new sensors stay dry, water or antifreeze will fry them again.
Vector
