Bad tires or bad bushings
Hi guys saw an cheap xj8 in good mechanical condition but when i drove it the car was making clunking noise and it was vibrating on rough streets only But if the street is clean and no bumps car is soft ride and no vibrating ist tires or subframe bushings?
Thanks.
Thanks.
What year, model? ...what do you consider cheap?
Initially I would conclude the usual, ...ball joints, ...maybe wheel bearing(s), ...front shocks, shock tower bushings, ...rear shocks, shock dampers, ...control arm bushings, ...tires (either bad or not balanced), ...bent rim? It could be any number of things, so for a small fee, going to a garage and asking them to give it the once over can save you a lot of money and/or prevent you from overpaying and give you a bargaining position.
Shocks and shocks bushings looks good . You mentioned so many parts which i think to fix these it will cost more than the car price itself
And then there is the engine/transmission. If the chains/tensioners have not been replaced that will be a few hundred if you do the work yourself. Thermostat housing and cooling system hoses may be due for a change and transmission pressure control valve update if the a drum is still good.
800$ for bushings work front and rear and about 500$ for set of tires let alone the tensioners the car did need lot of work and cash i didn't buy it
dak888
16
08-23-2014 07:42 AM
