Batteries
Im sorry if this seems like a dumb and simple question but here it goes regarding the H6-H7-H8 batteries its my understanding the H6 and H7 batteries are acceptable to interchange however the H8 battery is not? Its the same dimensions as the H7 only a little longer my H7 AGM puts out 1000CCA with 850CA my vehicle on parts checkers like autozone and oreillys it is listed that i need an H8 however i have a nearly new H7 AGM purchased roughly 6 months ago with the aforementioned 1000cca 850ca is this H7 battery okay to use? Will my XJR require the H8? Aside from the cold cranking amps and cranking amps? And can anyone tell me what the car’s electrical system expects? Sorry im confused in looking into this thank you ☺️
ForTheLoveOfCars (12-08-2023)
ForTheLoveOfCars (12-10-2023)
