Battery? Alternator? Relay? Short? Argh! Engine cuts after a few minutes - Resolved
Since the regulator is inside the alternator, someone is blowing smole somewhere! But the grounds and the bulkhead fittings are certainly worth checking. And BTW, the charging circuit on these caqrs is straightforward and ANY automotive electrician with even average skill SHOULD be able to diagnose this fairly quickly.
You have checked the alternator belt tension and made sure the belt is not somehow contaminated with oil, right? You need to determine if the problem is the battery, the alternator or the wiring. Go back and read Brutal's post about the voltage drop from the battery to the alternator. I would add that you should also check the voltage drop from the alternator case to the battery negative terminal for the same voltage.
I'll be doing a load test on the battery tonight to definitively take that out of the equation. The belt was in beautiful shape, no oil, and appeared to be under good tension. Once we have everything reassembled and can start her up, I'll double check for slippage.
I have a list as long as my arm of voltage/resistance checks to perform tonight, so hopefully I'll have identified my variable before midnight! Once again, I appreciate everyone's help. . .
Jim, I tried to identify which relay it was, but I couldn't put my finger on it. It seems to be one of the relays located under the tool tray/bulkhead area. There are a bunch there, so I couldn't pin it down. I switched them all up, so I'm pretty sure it's not a bad relay. I agree that it could still be what the relay is turning on that causes the issue.
I'm going to start at the basics and work my way through again. I know I have a good alternator. I'm going to confirm the battery with a load test. After that, I'll check the voltages on the multi-pin before reinstalling the alternator. Then it's belt slippage, then voltage and continuity tests, then relays.
If the Jaguar gods are kind, it's a battery with a bad cell that the voltage tested good, but fails under load and needs to be replaced.
Booty:
I don't know how fresh your electrical engineering skills are, so a few reminders might help streamline the process and give you a chance to go for a victory ride before midnight. Remember that voltage sums around a circuit. So if your battery is reading say, 13.7 volts and the alternator terminal to the alternator case ground is 15.0, you have a 1.3 volt drop in the connections from the alternator to the battery. To find whether that is on the power or the ground side, or split between the two, use Brutal's test method- read from the alternator power terminal to the battery plus. Then the alternator case to the battery ground should be the difference between the 1.3 volts read earlier and the power side loss. If either the power or the ground circuits are more than ABOUT .25 volts, you should look there for a bad connection. The ground path is easy, but if your power side has a big voltage drop, it is obviously harder to find.
I agree that is would be good to figure out what is happening when you hear the "click". The radiator fans, the AC system, or one of the evap system valves come to mind. That may or may not be part of the root cause, since the battery sghould float most any power draw not great enough to blow a fuse.
Your headlights on high beam make a pretty good load test at idle, meaning they draw about 10 - 15 amps, which is about what an alternator should do at idle. If you have a load tester, great, otherwise, turn on the headlights and measure battery voltage with and without the car running.
Alternator tested good, battery load tested good, eventually found the problem and fixed it. Voltage is now at 14 with brights and AC on. Everything else is perfect. So what was the culprit?!?
Drum roll please. . .
dubadubadubadubda. . .
THE GROUND STRAP!
Brutal is the winner with his prediction of:
It was burned up, corroded, and just plain nasty. Very cheap fix!
Thank you all so much. It's been a bit of a pain, I've gotten filthy, I've gotten bloody, but I feel like I've really gotten to know my car. This experience has had its highs and lows, but I guarantee I would have never had her running without this forum.
WOO-HOO!!!!
THE GROUND STRAP!
I would go to the ground strap. Matter of fact it is easily replaced with 2 bolts under the car from frame to body. It is down under the car getting water and grime on it constantly. We do replace a few a yr in texas. More north, more often.
WOO-HOO!!!!
#28
THE GROUND STRAP!
WOO-HOO!!!!
THE GROUND STRAP!
WOO-HOO!!!!
#30
Jimmy, when I initially read Brutal's post, that's what I thought he was referring to also.
The actual ground strap in question is just like the one attached to the battery, but is located underneath the car. It's about a foot behind and a foot inside the passenger side front wheel. Very easy to find once you're under there and looking for it.
I ran into a problem removing it because (I believe) someone working on the tranny used a longer bolt than standard on one end. Once they finished work, it was impossible to remove the bolt due to interference. I had to saw the bolt off and replace it. Normally it would be a piece of cake to replace.
I'd recommend all do a quick inspection and a tightening or replacement if necessary. Very cheap and easy fix that could prevent a load of headaches.
JimmyL (07-08-2011)
#31
A quick thanks for this extensive thread and for posting the resolution. I have been having some weird voltage drop issues ( mainly when electric fan engages ) and rough idle the moment after crank if a/c is on at startup. Wouldn't have thought to check the ground strap under the car so I will come daylight tomorrow, but I just wanted to prime your brains for help in case I find it intact.... Wish me luck!
#32
#33
#34
My 1999 XJ8 had the battery loosing power and it tested good, there was also an odor comming from the engine compartment, auto zone said it was the alternator, but a shop said the alternator was good, it ended up being a double threaded stud that is under the right hand side of the cars wheel well, it apperently connects the battery to the fuse box or something like that. It was a real simple fix. The part eas threaded on both ends and was about 2/3 inches long
#35
I'm having the same issue with my 1994 XJ12. I replaced the alternator 3 months ago and I have a brand new battery. I just got a decent amount of work done on my baby & now after getting it back for 5 days, the voltage went kaput. Trickle charged & was at a solid 14 & didn't faulter for a good 3 hours with lights & heat full blast. As soon as I took it to Advance Auto & they ran their test, it shot down to 12.3 volts & went downhill from there. I'm stymied & this happened a day ago, alternator, fuse or relay? Please help.
#36
if its clean and tight, probobly no tthe issue. I would go to the ground strap. Matter of fact it is easily replaced with 2 bolts under the car from frame to body. It is down under the car getting water and grime on it constantly. We do replace a few a yr in texas. More north, more often. And alternator doesnt need to be taken off to test. You only need a dvom to check voltages. In idle,test at the back of the +stud on the alt. Take the air box out but leave the mafs hooked up to allow room. . Check output without anything on, then switch on ac, blower set to high. All lights on etc.. And watch for what the alternator does. It should have no issue keeping up with only a momentary drop bewtween consumption and recovery. If ok go to the + post and measure the voltage. The differance between the battery and the back ogf the alt should never be more than .2volts or you dont have a low resitance connection between the 2.
BrentGardner
28
04-26-2024 03:08 AM
Andrew McVey
16
08-27-2015 07:21 PM
