Battery disconnected/reconnected still P1111
The other day my 2002 XJR went into restricted mode. I pulled over, disconnected the battery, reconnected it and hooked up my Autel OBD scanner.
It came up with two DTCs’ P1111 and P1121. I’m not so worried about P1121 yet. My throttle body was replaced only a few years ago. If it happens again I’ll first start cleaning all the various connectors etc. But after a reset I have driven the car several hundreds of kilometers and nothing appeared again. So far so good.
My question is on the P1111. I know you will always have the P1000 or the P1111 on our cars.
I’m just curious as to what will reset the P1111. I had the battery disconnected for about 30 seconds and it still showed P1111. Should a battery disconnect not reset the ECU to redo the drive test? I was expecting P1000.
Jeroen
Jeroen
Jeroen (11-12-2017)
Thanks, as I said, I’m familiar with P1000 and P1111.
I was just surprised to see P1111 after having had the battery disconnected for about half a minute. I would have thought that would reset the ECU to start the drive cycle. Hence I was expecting to see a P1000 after a battery disconnect, not a P1111.
That was my question:
Clearing DTC’s doesn’t change P1111 into P1000. Both are valid conditions.
Maybe a more advanced OBD scanner than my Autel MD802 or Autoengenuity with Jaguar Pack can reset P1111 into P1000. Mine can’t.
Jeroen
Jeroen
I don’t think you can clear/reset the P1111 as it is not an error, but a condition. At least nothing happens when I push clear on either my Autoengenuity or Autel OBD scanner.
Maybe it will take longer then 30 seconds. I’ll try next time
Jeroen
I already posted you can and how.
