Battery voltage questions/concerns
#41
#42
After that, you can pull fuses with full access to every compartment without waking the car up.
#43
#44
You just check the amps reading of the multimeter, set at 10A range and inserted in the negative side of the battery (when it is down to 0.05-0.06 A), each time you pull out a fuse. When you see that a certain fuse, when pulled out, causes some drop in the Amps reading at the battery, that's the first one which carries part of the parasitic draw. Then just go on with pulling the fuses until you get 0.00 A at the multimeter. Mark every fuse that caused drop at the multimeter. Do not re-insert the pulled out fuses until you finish the investigation (reach 0.00 A) as it may cause parts of the car electronics to wake up and mess up your reading of the multimeter.
#45
Not sure what year your car is, they changed the allocation of some fuses over the years, but most remained the same.
#46
So the fuse that gave me the 30-40 reading is for the rear heated seats. And it is indeed blown as well.
Did the parasitic draw test. Had everything latched, and car locked. Waited an hour. Pulled the fuse that gave me the 30-40 reading. Interestingly, the mutlimeter stayed at .06-.05
So, I said screw it. Started with pulling fuses one by one and checking the meter. When I pulled the number 1 fuse in the right rear compartment, under the seat, the meter went down to .03
That number 1 fuse is for the "left hand seat control module"
#47
#48
#49
In the case of your left seat module, you found that it draws some .02-.03 amps (its disconnection caused drop by this amount). According to the table below, each seat module should draw only .005 amps (0.5 mA) so your left seat module appears to be faulty as it draws excessive current (.02-.03 amps = 20-30 mA). It would be interesting to see how much your right seat module draws; if it is good, you should see practically no reduction in the current draw when you pull its fuse out. Here's a table showing which modules/systems normally draw current, and how much, when in sleep mode:
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x522/battery_drain_4b5eedfc1e22a2d5953d0b790f3d5263b95119fc.jpg)
#50
#51
Literally today was our first day with no rain. Found the Right seat control module fuse. It is located left heel board, fuse number 1, also 20amp. When I disconnected it, there was no voltage drop. Only when removing the left seat control module fuse, it shows voltage drop.
With that said, my left side driver's seat works fine. However I think the memory settings are not acting right. But I haven't been driving the car much. So I'll check that later today.
#52
So after a 15 mile drive yesterday, I read the voltage once I turned the car off, 12.69v
Checked the voltage another 18 hours later(this morning) and the votage read 12.27v, not cool.
Ran a parasitic draw test again. Had everything latched, doors locked. Switching between .03 and .04 every 3 or so seconds. I'm at a lost as to why it drained the battery so quickly.
#53
1. Old battery close to the end of its life; with cheaper batteries, this could be even just 1.5-2 years from new
2. A battery developed partial internal short in one or more of its cells
3. A battery which was, in the past, allowed to over-discharge. If the battery voltage is allowed to drop below 10.8 volts for some period of time (even a few days), an irreversible sulfation process will take place on its plates which eats-up the battery capacity. Such batteries can be revived (recharged) but will not take much charge and will not hold the charge for long i.e. will self-discharge rather fast. In bad cases of sulfation, the battery will still receive certain charge, will start the car easily and generally be ok for the day if the car is driven. Next morning - totally dead; even if the car does not have any parasitic current draw.
#54
#55
#57
#58
So after a 15 mile drive yesterday, I read the voltage once I turned the car off, 12.69v. Checked the voltage another 18 hours later(this morning) and the votage read 12.27v, not cool. Ran a parasitic draw test again. Had everything latched, doors locked. Switching between .03 and .04 every 3 or so seconds. I'm at a lost as to why it drained the battery so quickly.
So, I went investigating the parasitic drain and found out that all the extra drain of some 0.05 A (50 mA) was going through the fuse #7 of the LH Heelboard Fusebox, line "17" to the BPM. When I pulled this fuse out, the battery drain dropped to just 0.025 A (25 mA), well within the spec. I found out that the line "17" is for the BPM to control the interior lights and the shift lock solenoid (perhaps a few other things as well). Anyhow, with the fuse #7 out, I could still remote lock and unlock the car but the interior lights would not come on and I could not move the shifter from Park. Everything else work fine.
Obviously, the BPM is drawing additional current of 0.05 A for something and, as the shifter lock is completely off with the ignition off, I suspect the drain is through the interior lights. The BPM's electronic circuit for delayed interior lights switch-off may not completely switch them off but may leave the 0.05 A still flowing through the bulbs (this small current will not cause the bulbs to light or even glow so they look like they are off). I hope this can help somebody struggling with the battery parasitic drain.
I considered replacing the BPM but I am not really keen to do this because of the trouble with the synchronising or programming of the new (used) BPM. Instead, I am going to insert a solid state timer relay (~ 1 minute) in the line of the fuse #7 (line 17 to the BPM) which will first be switched on for 1 minute when unlocking the car (by the flash of the indicator lights) and then kept permanently on when the ignition is on. After switching the engine off and locking the car, the timer relay will hold the power in the line 17 to the BPM for about a minute and then cut it out eliminating the extra parasitic draw.
Samilcar (12-02-2018)
#59
Received 1,798 Likes
#60
