Battery voltage when is not running.
omgimali (11-05-2016)
12.55 sounds about normal for a sitting battery, on the lower end but not completely gone. The correct test would be a load test, not just measuring voltage with the multimeter, to see if the battery is still holding its full charge capacity. That should be what both your mechanic and advance did..
They need the volts to stay good during cranking and also at all other times or expect grief (RP, spurious fault messages, codes, misfires, etc).
